Upgrade PC Help
You can just use tape or something like that. Otherwise a cheap adapter can be bought. There are even ones available to accept into a PCI slot (if you prefer something else).
I was thinking about this one, while It was on special...
https://www.overclockers.co.uk/showproduct.php?prodid=HD-192-SA
Would I need a mounting tray?
Perfect SSD the evo 500Gb and get this adapter tray as your case doesn't have native 2.5" drive mounts.
Kolink 2.5" to 3.5" SSD or HDD Adapter plate with screws and rubber mounts
https://www.overclockers.co.uk/showproduct.php?prodid=HD-027-OK
You will only need one SSD for the windows and apps, use the WD Black you have for backups and storing your media for example. 500GB SSD will be a nice size for all the FSX add-ons and general use.
