Hi peeps,
I have a socket 775 Gigabyte GA-P35C-DS3R v2.0. This currently has a E6300 cpu at stock. It has the latest bios which is F12
I have recently bought a second hand E8400. It says on the Gigabyte website that it should be okay when I install it the computer gets through the bios/post screens.
Then it gets to the bit where it says loading windows and I get a blank screen afterwards. It seems that the hard drive is working as the red light is on and I can hear it pumping away but there is nothing on the screen.
If I remove the E8400 and replace it with my E6300 it boots straight away into windows.
I have emailed the seller of the chip but just in case there is anything I am doing wrong I thought I would post it on here for some help and advice?
Cheers
Adam
Cheers
Adam
