Upgrade question
28 Feb 2011
Norwich
Hey guys
so i've been gaming at 1080p 60hz since sandy came out and i think its time to get an upgrade this year
I have a 980ti and i was toying with the idea of 4k, but am i correct in understanding that most monitors run 4k at 30hz and most gpu's struggle to even keep the 30fps.
So i was curious what was more important, a higher refresh rate or a higher resolution? like 1080p/1200p @ 144hz or 4k @ 30hz
i see monitors at 4k @ 60hz but they seem out of my budget, can only really spend £300 without getting my ass handed to me by the mrs
If I were you I'd either get 1080/144hz or 1440P/60hz.
This is a good 1080p choice:
https://www.overclockers.co.uk/showproduct.php?prodid=MO-066-AC&groupid=17&catid=1120
as is this:
https://www.overclockers.co.uk/showproduct.php?prodid=MO-027-AO&groupid=17&catid=1120
If you're looking at 1440p (which I would take over 1080, especially with your card), then something like:
https://www.overclockers.co.uk/showproduct.php?prodid=MO-070-AC&groupid=17&catid=1120
Cheers buddy
Chose this bad boy on offer
https://www.overclockers.co.uk/showproduct.php?prodid=MO-082-DE&groupid=17&catid=1120
