Hi All,
I want to upgrade my GPU to a 4090 but have some questions i hope someone with more experiance can help with! I will try and keep this as concise as possible.
Current relevant specs are:
Monitor: LG 48GQ900-B 4k 120hz OLED
GPU: EVGA FTW3 1080ti
MB: Gigabyte Aorus x570
RAM: 32GB Corsair Vengence
CPU: AMD Ryzen 7 3700X
PSU: Sesonic Focus+ Gold 850W
Case: NZXT H510 Elite
CPU Cooler: 280mm NZXT Kraken X62
Questions:
1.My case with the AIO only has room for a 338mm GPU which restricts me to 2 MSI cards (that i have seen) however as they will be a squeese it would prevent airflow im my case and send temps sky high.
I have looked at 2 cases so far, Corsair 5000d Airflow and NZXT H7 Flow, currently favouring the 5000d, any better cases (preferably in white) for the same price range (£100-£150)?
2. Is my PSU capable of running a 4090? I have seen some that recommend 850w and some that ask for 1200w! I was looking at the Zotac cards that ask for 1000w.
3. If i do keep my current PSU, are the cables in the box 100% safe now? do i need to purchase any higher quality cables?
Can you see anything i have not considered? i generally dont like surprises that cost me money.
This PC is for 100% games, I have a work provided laptop for my work.
I undersand there may be a bit of a mismatch with a 3700X and a 4090, however as I will be playing at 4K it should't cause any issues(?) and i will likely upgrade to a 5800X3D sometime next year.
Originally i was looking at a 4080 or 7900XTX but i would still need a new case and by the time i look at mid level 4080s jumping to a 4090 is not that far out.
I would be keeping the 4090 for 5+ years.
Appreciate any help/advice/moral support!
Questions:
