- 18 Jul 2006
Hi
Thinking of upgrading next week and just wanted to check that this should all run ok together or if you would recommend any better components than the ones I've chose. I use it mostly for gaming and HD playback, and it'll be used with the rest of the spec in my sig. Also will my current 600w seasonic psu be enough to handle the upgrade as I'll be overclocking aswell?
I'll be wanting to sell on my old components but as I bought the pc pre-built (before I found this site unfortunately) I do not have the boxes etc that they came in. So would it just be a case of buying some anti-static bags and bubblewrap to keep them safe when selling them on?
Thanks in advance
Billy
Thanks in advance
Billy
