Upgrade thoughts?
12 Jan 2004
London
OK, seen as how im a tad disappointed with the 6990', thought i might as well blow some cash anyway and this is about my limit. Figured I would get a bundle and a 6950 and flash the bios. Then at a later date get in another 6950 (or by then probably a 6970) for crossfire. Upgrading from the spec in sig. Im a bit concerned about everything fitting into my Antec 300? will have to do some research.
Any thoughts, suggestions before i press the buy button?
Radon Torosaur OC bundle
- CPU: Intel Core i5 2500K 3.30GHz @ 4.40GHz Sandybridge CPU
- Motherboard: Gigabyte P67A-UD4 (Socket 1155) DDR3 Motherboard
- RAM: Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel
- Cooler: Corsair A50 CPU Cooler
- Artic Silver 5 Thermal Compound
HIS ATI Radeon HD 6950 2048MB GDDR5 PCI-Express Graphics Card
Total : £706.39
Looks fine, it'll fit in your case, however if you don't have too many HDDs, you might want to consider removing the HDD cage and using adapters for your 5.25" bays, gives you a lot more room at the bottom.
Thanks for the comments - ive got a couple of SSDs so thats a great idea Redmint.
But now youve put some thoughts in my head! Would the card be able to run three of these for mid-table gaming - mmos and FPS mostly?
Hanns.G HH251DPB 25" Widescreen LCD Monitor
Theyre relatively cheapo, bringing the total to about £1150. I'd be willing to take the huge amount of flak from the mrs so i could sit there and cackle all night long in eyefinity.
Lol, I wouldn't expect particularly good frames per sec using a single card in eyefinity, should be fine with CF especially if you're going to unlock the cards.
I'm slightly retarded.
Okay, so I can't read properly.
Okay okay, I just read the title and assumed the rest.
:( :o :(
Cookeh, read the 1st post a bit more carefully. :p
Oddly, I noticed that upon just opening the page again to read your comment.
lol ok, cheers for the tips, guess the kids get to eat this year. Ill stick with the original and a decent 25".
Cheers/
