My 2600k has been running at 5ghz since 2011! I couldn't believe it when I search for the invoices in my email.
I use two machines:
+ One big workstation (hackintosh) for Mac development, photo editing etc etc. This is currently the 2600k with 32GB.
+ One big(ger!) workstation (linux) for embedded/linux build. This one is a 5930K with 64GB. Barely overclocked.
I never felt the 5930K was anywhere as fast as the 2600k, despite the extra cores, even for building. It's still a good machine but I never felt it was 'screaming' fast.
Now, I'm pondering retiring the 2600K, use the 5930K machine as workstation, and building a new, bigass chassis/mobo/cpu etc.
I'm thinking Threadripper or a bigger Ryzen -- does that make sense? Any suggestion for my use pattern?
			I use two machines:
 Photo-editing and quite a few other tasks are mainly single threaded so higher Mhz/IPC rather than amount of cores will make the difference. So that 5Ghz of the 2600K will be quite a bit faster than the 3.7Ghz of the 5930k, even with the new architecture.
