Yes, as while it IS faster than the GTS250, it is not faster by a big enough margin to justify as an upgrade.My cpu is a dual core 2.8Ghz. I got told about bottlenecking and I'm concerned if this will happen with mine. so the GTX 550 is a bad choice?
5770 is pretty much around the same speed as the GTS550...so no.What if I was to get the Radeon 5770?
Would that be a good fit for my system?
I'd pick up a CPU later and yeh I'm on a tight budget.
What in your opinion would be better though? CPU or Gfx card? Ive only got 100 quid max to spend.
was looking at the GTX 550 Ti. is that any good?
1366x768 so if i can play Battlefield3 on that card on low-medium i honestly dont mind. will this be possible?
