Hi guys,
Did a search and saw numerous threads but none answered my questions.
I currently have a Sony Vaio C series Laptop with a 120GB HDD. I'm running out of space so it's time to upgrade!
I'll probaly be going for a 320GB and am aware the faster the RPM the better. Provided the dimensions of the HDD fit then its all good.
Now my actual questions:
I have the recovery disks for my laptop and all the cd's etc it came with.
Once I have installed the HDD do I need to just bung in the recovery disks and let it do its thing? will this also reinstall vista? I'm a bit
as I'm not sure If I have OS disks, or is the OS on the recvery disks?
Also will any size HDD work? provided the dimensions aren't so great it can't actually fit inside!
Sorry if it's not very clear!
Thanks in advance
Benny C
as I'm not sure If I have OS disks, or is the OS on the recvery disks?Also will any size HDD work? provided the dimensions aren't so great it can't actually fit inside!
Thanks in advance
Benny C
