upgrading my current system (advice needed please)
6 Nov 2015
Hi Guys,
This is my first ever post on this forum. I hope you don't mind me asking for some help on my first post.
I use my PC for work and downloading the odd thing. Work wise i only really use internet browsers, word, excel, and other similiar basic things. But i do run 3 monitors and one of these being a 30 inch one. So i do not need mega power.
But saying i dont need mega power i do spend my whole working day on it so i feel like i want to upgrade it a little.
Currently here is my rig out.
amd fx-4100 quad core -
motherboard - msi - 760gm-p23(fx) (ms-7641)
memory - ddr3 8gb - nb frequency 1999.9 mhz - dram frquency 66.6 mhz
graphics card - amd radeon r7 200 series ( i am happy with this card because it allows me to run 3 monitors)
1tb 7200rpm HD
Cheap £25 PSU
I have a good case i recently upgraded that i am happy with.
Windows 7 (i do not have a disc it came installed)
I have had someone tell that all i really need is to do the following upgrades:
- much much better psu
- replace the ram totally and bump it to 16gb
- solid state disk drive
- windows 10
Does this sound about right? If so can you's recommend me some good things of these too buy please?
I think i may also buy myself a new mouse.
Welcome to the forums!
To be honest, the only things I'd change would be the PSU and the SSD. I wouldn't personally upgrade to Win 10 yet, 7 is perfectly good. You can clone the drive using say Macrium reflect for free and avoid having to buy an operating system.
An SSD will make a huge difference and a good quality PSU reduces any risk of it going bang. You can keep the 1TB HDD and use it for storage.
You could upgrade to an FX-6300 to get a bit more grunt. Do you use the machine for anything other than office work/browsing. If you're not gaming, then you don't need masses of power.
Thanks for the speedy reply.
I was told look at seasonic PSUs at around 600watt. My current one is 700w but cheap.
I game on my ps4. I will buy that cpu though because i'd love a faster pc. Speed is main thing i am after.
Wouldn't a better speed ram bumped upto 16gb be advised also?
Even though i don't have a windows disc there is a product ID under "system" Can i not take a note of that and use it when i add the new components?
This would save me cloning and i could bump it too windows 10 then.
Once thing i really do need is ms office. I do not own it though as i am using starter for free.
