Upgrading soon for Elite Dangerous. Advice needed.
26 Aug 2009
Okay I've never been the type to upgrade for the sake of upgrading, nor am I into overclocking. I've been out of the PC upgrading scene for a few years since I upgraded in 2009 I think. My PC a good machine before my 6950 died on me and now I'm using 5450 which is just good enough to watch films.
So is it worth upgrading to say an i7 4930 or even a 4960?
My current PC specs are:
965 AMD
4gb of memory.
Asus M4N68T V2 motherboard which I hate because of the lack of sata ports.
Coolermaster 750W silent pro.
Various hard drives including a SSD for the O/S which is Windows 7 Ultimate.
I've got about £1400 to play with, but I'd like to get the Playseat Airforce and the X55 Rhino pro HOTAS.
Nvidia are, allegedly, going to launch their 800 series later this year so you may as well wait.
WRT the HOTAS you might want to go up a step to the Thrustmaster Cougar or Warthog.
I've looked at the Warthog, but it has no twist so you have to use pedals. I hate using pedals. Although the quality is much better, all metal I believe.
Pedals are much better than a twist for sims IME, but to each their own. I like a twist stick for FPS games, though.
I'm 45, I played the original Elite, which is why I can't wait for Elite Dangerous. To take me back to my childhood but with better graphics. Being 45 I find it hard enough to coordinate my hands never mind my hands and feet lol.
But I want to do this as cheaply and effectively as possible. I'm saving for a new motorbike to tour Europe next year. But believe it or not, having a PC good enough (and cheap enough) to play Elite at ultra settings is my main priority, even at the expense of the tour abroad. I can always wait later on next year to get the bike anyway.
I'm 47 and feel much the same, but you quickly get used to pedals - you drive, don't you?
My main base I can use Warthog HOTAS, CH pedals, Trackir5, Rift 2, as gaming enjoyment but at the cheapest and best control outside that I would say go for the Logitech Extreme 3D Pro Joystick. Twist, Throttle and a hat with a few buttons covers it for me on another pc.
This is the joystick I used for Elite Dangerous and I'm extremely happy with it.
Does anyone have any thoughts on the Saitek X-55 Rhino? £200 seems to be around my theoretical limit to spend on a peripheral that will probably only be used for one game.
I'm waiting for the 8xx series from nVidia and then massive upgrade time :)
I have the x52 pro and I love it with Elite Dangerous... fantastic :)
Stelly
Okay Stelly, if I go for a new video card will I have to change my mobo, cpu and memory? Like I said earlier, it seemed a good machine when I had my 6950.
Ahh right I didn't realise that. I thought the PCI requirements were for the slot you put them into. I had a video card which was a lower PCI version than the mobo I had and it would just black screen. I thought it just pertained to that?
