Upgrading wireless security
Caporegime
18 Oct 2002
London
Just had a skim through wireless faq and have a few queries...
Im trying to upgrade the security of our wireless network (current SSID on/no MAC filtering and using bog standard 128bit WEP key). A really stupid question but when i disable the SSID, how am i meant to find the network? It wont show on avaliable networks :o
Also which secutiry protocol should i use? WPA Personal, WPA2 Personal or WPA2 Mixed? How do they work in terms of connecting to the network?
Thanks for the help :)
Specifically add it. Can't remember how the Windows config works, but in the drivers I used there was a box to specify an SSID to connect to.
Ideally WPA2, but it depends what your other kit supports.
WPA should all be the same. You set a passphrase (up to 64 characters) on the router or whatever, and you'll have to provide it on all the client machines.
Ta - but whats the WPA key generator for? In router settings all it wants it to set up a passphrase...
Tried WPA2 Personal with a passphrase but no luck. It could see the network a few times (even though i turned off SSID), frist time it wanted a key (used passphrase) but wouldnt connect and next few times said the network was out of range. What am i doing wrong?
Well there's enough people who stick in an easy passphrase (like "password" "12345" etc) This can easily be hacked by brute force / dictionary attacks. You can use a generator if you can't think of a good passphrase.
ah makes sense :o
lol i used deepspacenine as trial one :p
Any major difference between TKIP and AES encryption?
Ok my computer doesnt seem to like WPA, so gone back to WEP. One final question, do i want to use open or shared?
EDIT - Also in router settings for WEP, there are up to 4 WEP keys. Why is this?
Waiting longer before bumping is always your friend.
AES is stronger. WPA with AES is more or less WPA2 though.
So you can choose between the 4?
Shared.
Cheers people. A bit more secure now...WEP 128Bit/SSID off/MAC filtered :)
Now i have to figure out how to fix my fluxuating ping problem :(
