Uphere RGB fan & Akasa Vegas Addressable RGB fan controller
Finally got the argb fans to light up, I left the PWM fan connectors on the mobo headers & used the Akasa Vegas argb controller for the 3 pin 5v connectors. To connect the fans to the control unit cables, I bought some 3 pin rgb to vdg converters (the vdg connector fits the Akasa jst sm connector ok).
Thanks to everyone for your input.
ATB
Greg
Hi, could you give me a clue as to where you bought the 3 pin RGB to VDG converters? I'm facing a similar problem with the 3 pin VDG header on my Gigabyte X470 Motherboard (2× 5v 3 pin VDG headers, 2× 12v 5 pin RGBW headers) - finding RGB kit that connects to either is very confusing.
Hi
I bought them from a famous auction site, on the packaging it says they are for Gigabyte use only and are VDG TO VD-G 3 pin 5v addressable RGB convertion cable..
Hope the info helps.
Regards
Greg
Hi
Regards
Greg
Thank you - Googled the exact term you mentioned and found them last night - got two winding their way to me sometime next week.
