UPS plane crash
Something has seriously gone wrong with the maintenance side of things. Especially on an plane which has been around for 40 years. Engine separation doesn't just happen.
Not sure I agree with the above post on slats. Left engine separation looks like it's caused a fire which had a further adverse effect on the tail engine. Full to the brim with fuel, heavy, and down to one engine on takeoff... :(
Saw a rumour the plane was delayed for engine maintenance. Could be an engineer feeling beyond guilty right now.
"Ground observers reported the aircraft had been delayed for about two hours for work on the left hand engine (engine #1), the engine #1 separated during the takeoff run, the center engine emitted streaks of flames, the aircraft impacted a UPS warehouse and ploughed through other facilities before coming to rest in a large plume of fire and smoke."
Well, certainly that needs to be looked into.
The MD-11 is essentially a DC-10 MAX, they were retired from passenger service globally over a decade ago and the cargo variants are only used by a couple of US shipping companies who are in the process of retiring them.
Considering the planes were in the process of being retired from service you have to ask how "on it" they will have been with maintenance.
Christ, imagine taking off for a regular shift and the last thing you see seconds before you die is your left engine come flying past. Horrible.
RIP to all who succumbed :(
The surveillance camera footage of it sideways into the ground is insane.
How does an engine just separate? Must be lack of maintenance?
It has happened to the DC-10 before (the predecessor the MD-11):
It wasn’t lack of maintenance (that isn’t a thing in aviation, but it’s a separate topic) but the engineers coming up with an alternative procedure that saved a lot of time and effort when removing the wing engines but caused other issues which led to the engine separation.
That was 1979 - times, processes and quality have Improved immeasurably since then, so the cause of this accident I would say will not be the same.
My money's on a manufacturing defect. Even the tiniest hairline crack in a bolt can fail catastrophically at the levels of stress experienced from a jet engine at full whack.
It looks like an older aircraft so manufacturing defect seems unlikely as the only things that would be relatively new in relation to the engine are likely to be the bolts/brackets and the engine itself and it's designed to be safe with a certain number of bolts/mounting points failing with enough leeway for it to be spotted in a routine timed/flight cycle check.
I suspect it's going to be a maintenance issue, either something not checked/missed in a check or someone messed up:(
It'll probably be a combination of factors/errors/poor decisions like most aviation incidents, when they all align you get a big bang.
I'm far from an airline tech but I'm sure that bolts are changed frequently on them.
We need @Tefal to chime in here tbh.
Actually no - they may have torque checks a number of hours after initial fitment or visual inspection for signs of rotation during deep checks but in my experience they aren’t lifed.
They may also be re-used when replacing the engine, but subject to non-destructive testing like x-ray or dye penetrant etc. for example.
Every manufacturer and airline will have different requirements and schedules though.
