Hiya my inner tubes on the front forks are corroded and its proving to be lots trouble to get it sorted! basically I now have a solution but its going to take a couple of extra weeks one fork has no leakage at all but the other has leaked a considerable amount (seals and oil were done less than 2 months ago)
my question is can I just top up the fork oil in my fork? the manual has a guide on how to change it which involves taking out the fork spring etc so you can measure the oil in there but can I just not take that lot out and just pour some extra fork oil in the top? the fork oil is less than 2 months old so wont be contaminated and its only for a couple of weeks I just want to know if there is any reason why I shouldnt?
Thanks!
Thanks!
