Urgent Help - Boot Failure
12 Aug 2011
Ok so have just put an SSD into my system in place of my old HDD.
Connected up via PSU and SATA cable, installed Windows into the SSD and Windows booted. All hunky dory.
Spent ages customising desktop and various preferences in Windows.
Rebooted and now I get
REBOOT AND SELECT PROPER BOOT DEVICE
OR INSTALL BOOT MEDIA INTO SELECTED BOOT DEVICE
So now I cannot boot into my new install of Windows at all.
The SSD is 'seen' in the BIOS, but when I boot from the Windows CD, it now doesn't see the drive as available for installation. Obviously it did when I installed Windows.
Please help! The PC won't boot and I can't install Windows again, so a bit buggered!
pop in the bios again and make sure the ssd is set to the top of the boot order/list
Yes it is. It's the only disk hooked up. Even when manually selecting the SSD from the boot menu i get this error. It's like the installation is corrupted or something but windows install now won't 'see' the disk
boot from windows dvd again and pick startup repair (you might need to repeat it a few times to fix it)
Have run startup repair 5 times now. Still won't boot and when booting to Windows CD it still doesn't recognise the SSD as a disk
I've gone into DISKPART and when I select LIST DISK I see:
- Disk 0 Online 232Gb free 0b (what the...)
When I do LIST PARTITION I see
* Partition 1 Primary 232Gb Offset 0b
Then when I type SELECT PARTITION 1 I get the error
'there is no partition selected'.
Ok an update
Startup repair detail shows the following message:
Root cause found: partition table is corrupt on disk
Repair action: partition table repair
Result: completed successfully error code 0x0
So even though it says it's completed the repair successfully, I still can't boot or select the drive to reinstall windows....
are you running latest mb bios? also tried bootingup in ide mode?
idk why its gone funny or whatelse you could try to fix it,any other machine to test the ssd in?
I just stumbled across a thread from someone with the same issue who said using the diskpart>clean command on the disk will solve the problem.
Is this safe to do?
I don't have access to another pc to test the disk so out of ideas other than sending the disk back so figure I have nothing to lose in trying!
idk ive never had to do that,cant make things any worse than they are atm?
somethings up with the boot record,corrupted or something
Lol that's what I figured! Might as well give it a try.
Ok good news, that has now allowed widows install to see the disk. Proceeding with a new install now so fingers crossed!
Are you overclocking ? if so, make sure you install windows at default settings, a lot of people don't realize how system demanding windows is, both install and boot, its very strange that your MBR got corrupted so easy and early on.
I do over clock but I was running at default for install.
Using the clean function of diskpart solved the issue. I have since performed the install again and everything seems hunky dory again.
Did you have the HDD in when you installed Windows on the SSD and have then removed the HDD?
I believe there can be a problem where Windows creates the System Partition on the HDD not the SSD, so removing the HDD would cause issues.
