Urgent help needed - Calling all Guru's! (new PC won't post)
5 Nov 2003
Chesterfield
OK got my new bits this morning fro OcUK - decided to put them together with bits from my shuttle.
PC7 PLUS
DFI UT SLi-D
4000+
1GB ballistix
Enermax 500w Liberty
AC Pro
Clean 200GB Spinpoint SATA2
Put it all together - the mobo lights up I pres the power on button and get literally 1 seconds worth of power, pretty much like a tiny burst, simply will not boot.
Any ideas?
To start with, try hot wireing the PSU (unwind a paper clip and touch a green and black wire together.)
Have you connected up the case speaker?
Is there something shorting out any components?
After all 3 stripe the PC to bare components and start adding in turn.
No, could this damage the PSU ?
Not Sure.
I'm already using bare min setup
I've just had a problem similar to this, and i had to rma my psu.
Try unplugging some stuff and then try a new psu if you can.
Just tried with different combos and no components plugged in and still exactly the same happens
is the light on the mobo when its turned off?
And try it when everythings out of the case, but id be thinking about trying to find another pc to test the psu in
