I've replaced my graphics card this morning and when I turned it on afterwards, it would turn on for about 5 seconds, the fans would kick in and it would shut down. It repeats doing this endlessly until you either flick the power switch on the PSU or pull out the power cable. Pressing reset or the power button on the front doesn't do anything.
The monitor never starts up. Nothing really happens other than you can hear that its actually on.
So I removed the graphics card thinking it was faulty and turned it on. The same thing happens. Nothing.
So I put my old one back in. And still nothing.
I have no idea what I've done. Does anyone know what I can do to fix it?
As for cable length, they're about normal really - not massively long but long enough... it's hard to say. You can always send the PSU back if it's not right for you!
