the problem i have is..... when i switch my pc on its starts for about 5 seconds then shuts down then restarts then shuts down etc etc. if you keep your finger pressed on the clear cmos button at the back its continues uptil you let it go then it goes into the cycle of start/stop/start,
it never gets into the boot screen so i have no fault codes or anything to go on.
how can i tell if its a mobo problem or a cpu problem?
