- 18 May 2025
- Herfordshire
So each time I added my keyboard with a usb-c to usb-a cable, I got error 99.There's no need to replace the RAM if it works (which apparently it does?), it is just more likely to not work (especially "out of the box" with XMP/EXPO enabled).
Can you let us know how you fixed it? For anyone else that has the same problem.
To get rid of it, I had to reset the BIOS.
But each time I connected, error 99 would come again.
So I cleared BIOS, went into the BIOS settings, connected the keyboard, and A9 came-up (as I was in BIOS settings).
I then inserted my Windows 11 flash drive,, saved settings and exited BIOS. The PC restarted and booted to proceed with Windows installation.
