Urgent help on PSU
23 Dec 2008
I have just bought a Bitfenix Prodigy. And my existing PSU Corsair TX750W won't fit, it's a non modular.
Could you please advise which PUS (whatever make) that is know to fit into the Bitfenix Prodigy case. I prefer as high wattage as possible!
Thanks!!!
Thanks!!!
Have you actually tried fitting it or are you assuming it wont fit because it is non modular?
Prodigy: PSU cage depth 180mm, max PSU depth 160mm
TX750W: 150mm(W) x 86mm(H) x 160mm(L)
I have successfully get it going. The way that you installed PSU is different than other machines.
Now that I have it running. The CPu temp is 30 degrees at idle. Is it
good?
