- 6 Jan 2010
- Leicester
so i was at my dads work comp with all the cctv footage off his shop because i recently purchased a gfx and the computer it was inteded for had a cpu blow out so i decided to install it in this prefectly working pc.
so i turned off the pc and took out a gfx i didnt kno off i think asus gef 6200 le and put the new one, palit gforce 210 512mb in it.
so it booted perfectly,got the drivers installed asked for a reboot gave it one then the bad news.the start loading screen for xp the one that you get when your booting the blue dots going >>>> that finshed.a mom later it came again :S.and followed by a blue screen saying somthing about memory so i rebooted it. it still came. so i went into safe mode and safe mode appeared. so i went and disabled the ex asus gfx driver then it asked for a reboot. wich made it even worse
the blue screen still comes but now even safe mode dosent load even after waitn 30 mins
on one occasion instead of the blue screen the chkdisk came and was complted but after the blue screen was still comming i then decided to put the old gfx back in
good news it got past windows xp boot screen the blue dotty one but after that everythting when blank even after a few hours nothing
and safe mode wasnt loading
if anyone helps me fix this problem i will be over the moon
it is a core 2 duo 2gb generic ddr2 ram an asus pld52(some other numbers/letter)/1333
stupid mobo dont have a intergrated vga so idk whats causing the problem
the hdd has 5gb space
