urgent help required please
19 Aug 2009
im doing my new build at the moment and im stuck lol, im using a p180 mini case and it has 2 usb ports on the front, the two wires coming from the front panel have 5 wires on each plug,
wire 1 labeled usb 1
vcc1
data-1
data+1
gnd1
sheild1
wire 2 labeled usb 2
vcc2
data-1
you get the idea lol
question is where do these plugs go ?
does 1 go to the fusb1 header and the other to fusb2 on the mobo ?
only reason im asking is each header on the mobo has 9 pins so obviously if i plug one connector into each one some pins arent going to be used,
anyone shed any light please ?
Matt
sorry i forgot to mention the wires are in a black connector, slim with 5 wires in each one,
just want to know wether usb 1 and 2 go into the sme header on the mobo
thanks
Look in mobo manual and find out which pin on mobo header is Ground, and which is Data +ve.
Plug in the lead so that those pins line up with appropriate labels on the plug.
u do know u dont need to attach them for usb ? u can still use back ones . justa idea but like others said read manual
