Urgent help required!!
14 Dec 2004
Bridgwater, Somerset
Urgent help required!! PLEASE!!
I'm in need of a little bit of advice as I'm just building up my new AM2 rig and I'm a little confused as to what plug to use for the 12v line for the motherboard? Please can anyone help me? Picture below :
I have a OC Z 520W PowerStream PSU and I wasnt sure which connection to use... I thought it was the P4 connection, the one without the +P4 marked on it..
Into this:
Many thanks for the help in advance :) Please help!!
Did you plug it in or just leave it?
Think you can just plug it in one way round and leave 4 of the pins overhanging (assuming it doesn't clash).
Jokester
MeatLoaf said:
If its the same as my tagan the 8 pin plug splits in 2
I think you're right, on closer inspection that ridge in the middle is the clip for holding the 2 halves together.
Jokester
Yes, the blue plug does split in half. I wouldn't of thought it mattered which plug you use as they should both have 2 x 12v and 2 x 0v (GND), they will just be on different rails :)
