Urgent help
27 Apr 2007
Edinburgh
Hi people got a bit of a dilemma and hoping somone can help me asap.
I just received my 3870x2 and have just run into trouble with my power supply. Apparently I should have 2 8 pin pci express connectors and 4 6 pin pci express connectors. So far I cant find the 8 pin connectors so I can install my gfx card.
Would it still work with 2 6 pin connectors? and if it does which side do I put the 2nd 6 pin connector. Right to left or left to right?
A quick answer would be really appreciated
Thanks!
hi
yes it will run fine with the 2 6 pin connectors it just wont o/clock. i thought there would be only one way to fit the pins
cheers
So would you just put the 6 pin connector directly into the middle leaving 2 spaces either side? or have insert it from the either side leaving a gap on the other end?
hi
i dont know pal ive not got one but im sure someone on here wilth a 3870x2 will be along shortly to help
cheers
It will only fit one way, and you can still Overclock using another APP, just not ATI's OverDrive, even then you can short 2 pins and get it working.
When looking at your card from outside the case, you want to be leaving the 2 pins on the left of the connector on right:
Left Connector
Right Connector
Where the | is, dont have anything connected to it.
Hope that makes sense.
Thanks!
Dont worry, the 8pin is just a new safty standard for PCIE external power connection. The extra 2 pins are just for ground.
IT DOESN'T AFFECT OVERCLOCKING EITHER. :)
You could certainly ignore the wrong info from the first reply post.
Got it working thanks to you guys!
Just annoyed at the fact my psu didn't come with the 8 pin connector like it says it does on the box :S
But once again thanks for the help and it is certainly appreciated :)
