URGENT HELP
17 Jun 2009
Swansea
could sum1 tell me if this chip is easily overclockable or if its any good?
Intel Core™ i7- 920 SLBCH 2.66GHZ Quad Core processor ?
it is socket Socket LGA1366 which will work in a rampage 2 ?
Aye that's the C0 stepping i7 920 - good chip. It is indeed s1366 and should work fine with the Rampage 2 motherboard.
Usually overclocks pretty easily to 3.7-3.8GHz with decent air cooling, getting it up to 4GHz usually requires quite a bit more more volts/cooling in my experience.
How much are you getting this chip for? If it is close to this price, then I would instead suggest getting the newer D0 stepping which overclocks a bit better.
How long is that OEM likely to be there for?
At a guess: 2 months give or take. I hear the 920 will be replaced with the slightly faster 930 in a few months.
However, the 930 will likely based on the same D0 stepping, just a slightly higher multiplier - it will probably overclock just as well as an i7 920 D0.
