USB 1 to USB 2
5 Jun 2005
Southampton
i know you can get cards that go inside pc's but can you get external hubs that will plug into an old pc with USB 1 and then output USB 2?
You can connect a USB 2 hub but it will only run at USB1 speeds as you link between you PC and the hub is the USB1 port that you are plugged into. The only way to change is to do as you say and put a usb2 pci card in your pc
