I just got myself a Corsair 550D and i have a problem with the front panel USB3 ports. I just plugged in my trusty Corsair Flash Voyager 2.0 in but it does not work (works fine on my laptop).
If USB 2.0 devices are meant to work on USB 3.0 ports then the only other explanation is the USB 3.0 header on my motherboard. One of the pins was misaligned stopping me from plugging in the front panel cable. I gently coaxed it back in to position and the cable went in fine. How likely is it that my USB 3 header is completely narfed?
Thanks
Thanks
All sorted now.
