Hi,
I have a usb 3.0 card reader on a usb 3.0 slot and it is stopping pc from getting past ACHI check in bios.
if i pull it out it goes into windows fine and i can then connect the reader and all is well.
I done a google search and found others with this problem (all gigabyte boards i might add) but no one has a solution.
Any ideas?
Any ideas?
