USB 3 Stick in USB2 port
18 Oct 2002
UK
So I know it'll work, and some of the cheaper USB sticks are roughly the same for USB2/3 £12ish.
But is a USB3 stick any faster in a USB2 port than a normal USB2 stick?
Or is it better to buy one of the dedicated 'fast' USB2 sticks that are around?
I'm eager to upgrade by 5 year old 4 gig stick!
I have a 32GB Corsair Flash Voyager USB 3.0 memory stick.
Plugged into a USB 2.0 port the write speed is ~29MB/s which is about as fast as USB 2.0 goes.
USB2 and USB3 standards are 480Mb/s and 5Gb/s
USB2 stick R/W speed is totally different... in the 80Mb/s & 40Mb/s range.
USB3 stick R/W speed is usually better... some actually as fast or slightly faster than USB2 standards.
http://usbspeed.nirsoft.net/?g=4gb
Edit: 1MB = 8Mb
Theoretical bandwidth doesn't mean much.
The maximum actual read/write speed you'll see from USB 2.0 is ~30MB/s.
It's the same with SATA.
SATA 2 theoretical bandwidth 375MB/s, in actual usage more like 275MB/s.
SATA 3 theoretical bandwidth 750MB/s, in actual usage more like 550MB/s.
Edit: 1MB = 8Mb
Testing at the link there and my current stick is:
Read: 7.5 MB/S
Write: 5.4 MB/s
So anything is probably better!
Read: 7.5 MB/S
Write: 5.4 MB/s
I wouldn't bet on that. Most sticks have no data of what their r/w speed as.
Some USB3 sticks give performance up to half of USB2 spec. ;)
Google "Benchmarks USB Thumb Drive Charts"
