So I'm currently using a really cheap and nasty microphone at the moment, I plan to upgrade this to something worthy of upgrading to.
The new setup will be used for anything from voice chat, voiceover's and potentially recording for music purposes.
Looks like there are a couple of viable options to go for.
First one is an audio interface like the Forcusrite Scarlett series, with an xlr microphone plugged into that (maybe something like a RODE NT1-A).
The Scarlett's always seem to get good reviews, though I'm not sure what the driver support is like or if it is like bluemicrophone's usb mics where you don't need to download a special driver and it just works.
The next option is to get a relatively simple 2-4 channel mixer, and either have one that is a usb model (so use it as a usb audio interface), or have the mixers output plugged into my soundcard.
This option probably gives the most flexibility but I'm not sure it would actually be worth it.
So I'm looking opinions from anyone who happens to be running a setup similar to one of the above and can give some advice on what they think of it, limitations/issues with that setup etc.
