USB Barel Cable 3.5 inch hard drives
10 Jan 2012
UK
3.5 inch hard drives come with a regular PLUG with a barrel connector.
Whats the name of that barrel connector?
I have one that looks exactly the same but its tiny bit longer and doesn't work.
If you mean the power connector, I'm not sure it has an official name but 'power plug' will probably find what you want. It's likely that your USB drive has a 2.1mm socket but your plug is 2.5mm so doesn't make proper contact.
Usually is called a barrel connector
Like you said
Guess it's also a coaxial power connector or tip connector
Or concentric barrel connector
My external usb Dock can use a basic cctv power supply
Which I think is 5.5mm x 2.1mm
Make sure you use the right voltage adapter. a lot of 19v psus use the same barrel tip while your hdd enclosure might only be 12v.
