The initial windows popup states that that "Unknown USB device needs more power than the port can supply" - It's just my Steelseries wireless dongle.
Z790 Dark Hero with an Lian Li O11D XL case. I've tried with and without the additional 8pin for the header, but I keep getting this warning. Tried reseating the cable. Is this more likely to be a dodgy case cable issue, or a motherboard header issue? Dongle works fine on the rear USB-C ports, so it's not that. Anyone had this before and actually fixed it?
You could try a PCI card with a front panel connector on it to confirm / rule out?
