USB C PCIe Card advice
26 Dec 2021
Sowerby Bridge
My daughter has a problem connecting XP pen Artist Pro 14 Gen 2 to her pc with AC97 3 in 1 cable .
It works on my laptop through usb-C port so I'm wondering whether I could install a usb C PCIe Card into her PC to power that tablet.
Which usb c PCIe card would be good to power that tablet?
Thank you
Thx M8 for your help.
Your welcome
I asked ai and the answer given.
it almost certainly lacks sufficient power from the USB port. Use the dedicated USB-C to USB-A cable connected directly to a wall power adapter rather than relying solely on your computer's USB ports
Your welcome
yes that's correct I need upgrade her pc
