USB Card reader & CF card issues - Check my logic please!
30 Jun 2011
Birmingham UK
Can you do me a favour and listen to a series of statements that have led me to the conclusion that 2 Akasa AK-ICR-14 card readers are faulty and not my CF card...... I have a video camera using SD cards and a DSLR that can use either CF or SD.
The card reader will not recognise the CF card from my DSLR. Does not appear in my computer or photo editing program
The card reader recognises the SD card from my video camera. Pops up in my computer instantly
The card reader recognises the SD card from my DSLR. Shows in my computer instantly
If I use an old plug and play USB card reader the CF card show in my computer instantly and also in the photo editing program
On my old PC both CF and SD have always worked fine.
So my conclusion is based on the CF card working fine everywhere else except in the new Akasa, the PC recognises the CF card if connected by another device, The same files if on an SD card are picked up instantly by the Akasa.
I'm trying to find another CF card to try, but I can pretty much say the CF card is fine. (Sandisk Extreme 4 8GB)
Thoughts appreciated.
I went through the same heartache with dreaded Akasa trying to find a decent USB 3.0 reader. There doesn’t seem to be any good internal with long guide rails. After doing a lot of research I ended up with Lexar Professional USB 3.0 Dual-Slot Reader Card Reader, it is absolutely awesome.
AsRock Z68 Ex4 G3, [email protected], Ballistic Tracers 16GB,
5850 1GB(CFX), CM90 II Advanced, Crucial M4 256GB, 4 HDDs,
NH-D14, XFX 850W BE, Xonar Essence STX, BlackGold HD DVB.
