This is one that I have failed to solve.
Its a SANDISK 32GB and its a dual one, and has USB3 and Micro USB on it and it kind of slides across.
Its had no use out of it, I have almost filled it up with a load of stuff for a friend, and when I went to add some more stuff onto it, it failes.
I have tried to do the registry fix, but the info was not there and so I added it but this didnt help.
I have downloaded the SanDisk tools to fix it and the tools say that the READ ONLY is now disabled but Windows still wont let me do anythign to either the files or the partition on it, nor do everything else I try.
I have tried a couple of other disk tools that are supposed to bypass the R/W of USB drives and they dont help either?
Its only 32GB and so its no big deal as I have loads of flashdrives, but the thing has only ben used once and thats the bit thats bugging me. Sending it of to get checked out would probably cost me more than simply running to tescos and buying anothe, and no, I dont have the receipt from tesco either?
Anyone suggest anything ?
