I need a little help please. My brother gave me his son's 64gb flash drive so I could put some photos and stuff on there for him, but I am having a problem where anything I put on there seem's to fall into a black hole!
He gave the drive with about 15gb of random files on there that were not to be deleted. To keep things tidy I created a new folder called Previous Files and dragged and them in there and made a new folder called new stuff and copied about 16gb of stuff into that folder.
When I try and access the folders they are showing as 0 bytes and nothing in there, but when looking at the drive through my computer it's still showing as 30ish gb used.
I have also noted that then drive is using FAT32 file format for some reason and the rest of my drives are NTFS.
Whats really strange, is that if I copy a single mp3 file to the drive it's visible and plays fine, but when I remove the drive and plug it back in I can see the mp3 but windows tells me it's not readable.
I'm on Windows 7 home premium if that helps, and any help would be appreciated!
Thanks
Thanks
