are they any good? been watching a freecom one on ebay - currently at about 30 squid. just wondered what the qual is like?
is there a better make?
There's always something better.....I'd recommend Terratec...dig deep in the specs and you'll see why it wins hands down on any of the 'cheaper' reciever.ALLI said:are they any good? been watching a freecom one on ebay - currently at about 30 squid. just wondered what the qual is like?
sniper2006 said:There's always something better.....I'd recommend Terratec...dig deep in the specs and you'll see why it wins hands down on any of the 'cheaper' reciever.
Baron_Samedi said:Picture quality is brilliant using the house aerial wiring. I live in a poor signal area so using the supplied bit of wire is pointless.
For the price range it's brilliant. I certainly didn't need to send it back for a more expensive replacement!
PinkFloyd said:I have the freecom one. I keep meaning to send it back as the software is *cough* rubbish (to put it nicely)
It doesn't install easily, it took me ages to get working, then it stopped working since I swapped the usb ports it was in, hasnt worked since.
