usb hard drive
7 Mar 2005
Wolverhampton
Hi guys,
Im after a big USB hard drive that I can put movie files onto and take it to my blue ray player in other room.
What's the best ? Don't want to spend a lot. I have a USB stick for the smaller files but it just crashes when using bigger files!
Cheers.
You know that FAT32 formatted drives can't hold files greater than 4GB, right?
You will need to find out if your blu ray player supports other filesystems (exfat/ntfs/ext3) or you will be limited to 4GB files anyway.
My player reads FAT32 and NTFS.
My current USB stick is formatted to NTFS also and it ready that.
My player is a Sony BDV - E280.
