Usb has partitioned itself..
18 Mar 2012
Eastbourne
I went to use my USB today and it has decided to partition itself, thought i'd format it, still being annoying. I have had a google and tried something in Command Prompt but It didn't work.
It's Disk 2.
Help please?
are you able to delete the other 2 partitions? can see most of the space s sitting unallocated.
delete the new volume and the 99mb volume partitions and then you should see it appearing as one unallocated space, create a new partition and should be good
I've tried to delete the new volume, allocate the big bit, format to FAT and NTFS. Still no nothing. I thought it was going to be as easy as that too!
open up command prompt and type disk part
after type list disk and make a note of which one is the USB stick
then type select disk 1 (or what ever the USB is numbered)
once selected type clean
this should remove all partitions and give you one unallocated space for the USB stick, close down and create a simple volume through disk management
just tested on my USB stick here and worked
