Hey guys,
Not sure if I am being completely dumb (I probably am
) but I have got a USB DVI KVM 2 port switch, and for some reason I cannot get it to work - I'm sure I am doing something totally wrong but cant work out what
So KVM is powered on and I have in the DVI Out port the DVI cable from my monitor into the port and also the mouse and keyboard, mouse and keyboard work fine but the display doesn't show anything, I have checked it's on DVI / Digital setting on the screen. USB cables are connected.
I have plugged the cable from the screen again directly to the PC and it works ok, but going thruogh the KVM it doesnt show anything, Is the DVI cable supposed to go elsewhere? (only place it can go is in one of the DVI in ports?)
Thanks!
) but I have got a USB DVI KVM 2 port switch, and for some reason I cannot get it to work - I'm sure I am doing something totally wrong but cant work out whatSo KVM is powered on and I have in the DVI Out port the DVI cable from my monitor into the port and also the mouse and keyboard, mouse and keyboard work fine but the display doesn't show anything, I have checked it's on DVI / Digital setting on the screen. USB cables are connected.
Thanks!
