- 30 Dec 2019
- Deeside, North Wales
My AOC G2460PF uses a HDMI input, and has 5 usb ports, could any of these be used for a webcam, or does it have to plugged into the PC? Thanks.
Once you connect the cable from the monitor to the PC, all the ports on the monitor will become like the normal usb ports on your pc.
Yes I meant the USB cable, one should come with the monitor.I don't think the HDMI will carry a USB signal. Or do you mean a USB cable?
