Use Freesync or not
14 Feb 2008
I now have a 6800xt after swapping my 2080 Super and not sure whether to use freesync or not. The reason why is because it only supports up to 90Hz and my monitor ASUS MG279Q, but my monitor can run at 144Hz. The main games I play are L4D, GFTO, Vermintide 2 and I play IL2 flightsim in VR. I guess the VR doesn't matter as that doesn't use the monitor really.
So I'm unsure whether to use it or just stick with it turned off and max out the fps.
That seems odd, I have a 6900XT and am getting 120Hz free-sync, i.e. the full range the screen supports 48 to 120Hz.
Is this a "bug" with the monitor that its free-sync range is capped at less than its max?
Just having "enhanced sync" on (you can use it with FS too) and setting a fixed rate might be fine too. Maybe compare with 90 and 120 and see how much difference to the feel you notice.
The frame rate may be more consistent at 90 and if you have Radeon Chill on or a cap in the game, you'll also use less electricity. ;)
Looking at the monitor spec its a very early Freesync implementation, which is why the range is onlly 45-90Hz.
Might be possible to extend the FreeSync range with CRU, have a google and see if it's possible.
I will look into this.
Sounds like a monitor upgrade is on the cards... ;)
It is something I will do later this year, though I am very happy with my current monitor.
I can highly recommend a good HDMI 2.1 TV. :) Maybe wait for the 2021 models, they look promising and with full 48Gbps.
Something to think about when looking for my next upgrade.
Thank you for the input everyone, I think for now I will stay with it off.
Geforce also supports Freesync now, why would you want your FPS to be higher than what the monitor can display? It won't make any difference, and freesync is attached to monitor signal, so it should not affect other displays.
