Use Mobo Raid or my PCI Sil3114 Raid Card
30 Nov 2005
As the title really, i'm using 2 X 74GB raptors for my o/s games etc, i have a silicon image 3114 pci raid card (4 port sata) and I have an asus striker on pre-order, so should i just use the motherboard raid? I will have 3 other hdds attached. 2 X 400gb and 1 200GB in jbod. I intend to add another 2 400gb drives though very soon (jbod again) hence there won't be enough ports on the board. So which option should i choose?
1, put the raptors on the pci card (max pci-mobo speed is 266MB/sec might i add) and leave all the storage drives on the mobo.
2, put the raptors and 1 storage drive on the mobo and leave the others on the pci card in jbod mode.
I suppose either way will work, but any suggestions?
Normal PCI bus speed is 133Mb/s are you using PCI-X?? If you are then it's sensible to use the card for the Raptors, otherwise use the onboard RAID.
To be honest not a huge amount, mainly the ability to lift it from one machine to another without losing the array. If the card and board are PCI-X (yet to be confirmed) then there isn't a bandwidth issue to worry about so there's no reason not to use the card really.
I'm not too sure if its pci-express to be honest
The specs are as follows, it also has an image showing the controller and a motherboard with an arrow between them saying PCI BUS 266MB/sec
General
Hot Spare and On-line Mirror Rebuilding.
System GUI Monitoring Utility
Displays/sLogs/Alerts Users to Vital RAID Set Information
Manages RAID Set Functions (configures and rebuilds, etc.)
SiI 3114
SATALink 4-Port PCI Host Controller
SiI 3114 is a single-chip PCI to 4-port Serial ATA (SATA) host controller. The chip is ideal for applications such as servers, workstations and storage systems featuring peripherals with this new storage interface standard. Based on a 32-bit/66 MHz PCI interface, the SiI 3114 provides support for four independent Serial ATA devices and may be incorporated into motherboard or PCI add-in card designs.
Applications: Embedded Applications, Host Bus Adapters, PC Add-in Cards, PC Motherboards, RAID Subsystems, Server Motherboards
SiI 3114 Serial ATA
This is a tricky one. The SI 3114 is a chipset which can either be integrated onto a motherboard or mounted on a card. Now the chipset can cope with running on a 66MHz PCI bus IF it's on a card which can run at that speed AND that card is mounted in a 66MHz PCI slot.
What board are you using?
OK that board only has PCIe and plain PCI slots so your RAID card will only run at 133Mb/s. Therefore for best performance you'll want to put the Raptors on the on board RAID controller.
