If you have any cable modem other than a little blue one with ntl: Home 250 underneath it, and you are getting dropouts/poor performance, then give CS a call and ask for a modem swap.
ntl: Home 100s and 120s cannot fully support 10MB at the moment. Firmware to 'fix' it is still unstable, so I suggest you switch your modem for the 250 - I did, and I got a stable full 10MB connection instantly.
Hope this helps some of you
