- 7 Sep 2010
I'm almost decided on my new SSD, having heard great things about them in general (and horror stories about specific models). Two top candidates are the Crucial M4 and Corsair Force 3 (not sure about OCZ Agility 3's, Vertex 3's are too much, dunno about Adata
), and here's the comparison :
http://www.anandtech.com/bench/Product/400?vs=355
[NB - Why do Anandtech mix 'Higher is better/Lower is better' results? It makes a quick glance comparison very tricky.]
Some results are close (within 10%), others are more than 100% different, on both sides. I think the M4 wins overall, but without knowing the real-world relevance of each benchmark it's difficult to be sure. So my question is :
What's the most useful/meaningful/reliable benchmark for real-world use?
I realise everyone uses their PC/SSD differently, but I would be using the SSD as a boot drive for Win7, plus a few apps (which I guess is the most common setup until they become radically cheaper per GB). To further complicate the answer (if there is a single answer), if I get a larger (120GB+) SSD I could use a partition on it for SSD-caching with my Z68 mobo - would this rely more heavily on writes?
I know there's no simple answer (although "Incompressible Sequential Read" would be my guess), and there are many compound benchmarks (such as Anandtech's Heavy/Light Workloads 2011). I'm on a budget (<£150 for 120GB SATA-III), but I'm really after an explanation of various benchmarks than a recommendation of a specific SSD.
