Hi all,
I'm looking to get a new, cheap, basic C2D setup (probably using something like the GA-73PVM-S2) for my CarPC setup to replace an ageing Athlon XP setup!
However, my power supply unit is only a 20-pin ATX jobbie - will this work on the newer boards with a 24-pin power connector? There isn't any CarPC specific power supplies with a 24-pin connector as far as I'm aware (and my PSU works, so don't really want to be changing it if I can help it!)
Cheers!
Cheers!
Works fine on my rig but cant say regarding newer ones.
