Simple as the above. The loop will only have a radiator and a gfx card in it to start with, but assuming things go well it's going to end up with everything I can find which gives out heat attached. No reservoir, will be using 10/8mm compression connections with 11/8mm tube.
I'm looking at the D5 and the DDC with one of the aftermarket tops. The price difference is fairly minor, the difference in pressure head is 3.7 on the D5, 4.7 on the DDC 18W.
The smaller is a DC motor, the D5 an AC one which changes input voltage appropriately. So either can be run from the internal power supply. Basically I'm a bit thrown by this, the bigger one appears to cost more and offer a lower pressure head than the smaller. Which do I want to go for or does it simply not matter?
Second, can I change the speed of these using a fan header? I think Asus told me they were rated for 24W, but I'm not sure I trust the email I got from them much. Especially as I can't find it, and my memory isn't perfect.
Cheers
edit: It appears that the far more sensible option is running them directly from molex. I'll wire a pot into the 12V line if I need to and control it manually.
Probably going to settle on the ddc with some form of aftermarket top, but still can't find a significant difference between them
Cheers
