Seems like it's all down to experience from what you're saying. I'll see if i can gather some materials together aswel and try everything tomorrow.
I used a dremel to cut perspex and the thickness made it a NIGHTMARE task!
When cutting plastics etc do not use too high a speed or it will just melt.
The friction based cutting discs are really not meant for cutting plastics, whereas spring steel cutters are designed for it. They are flexible and very forgiving, I haven't broken one cutting plastic. Also they doesn't melt the plastic so there are no carcinogenic fumes.
Yep practice is the best way to get good at it.
water would work, but I think a drop of oil would stay on the work piece better without getting flung all over the place.So low speed and gently touch the plexi? Would adding water while cutting help?
