Don
- 20 Oct 2002
- Oxfordshire / Bucks
Jay123 said:well yes??? they normal come with speakers in the year 2007![]()
they dont really
my new one hasen't lol
JsD said:If you're looking for an LCD for TV functions I'm going to shamelessly plug the LG M208WA and M228WA range. Well if you can find anywhere stocking them!
Their only limitation is that they use TN, but I honestly haven't found that to be a problem with these monitors.
AHOLLA said:Hey JsD - have you got either of these monitors... i was thinking about getting one but then found out about all the details you need to check when buying and LCD and wondered how it delt with th efollowing:
Backlight bleed
Viewing angles
Scaleing - 10:16 - 9:16
Ghosting!!!
THanks!
AHOLLA said:Cool - well il look forward to the review.
and with regards to scaling, playing high def content made for 16:9 gets streched to the 16:10 that these monitors support, the whole 1050 thing. Happens on some monitors.
MagicalTrevor said:If I post a link to someone who stocks are 7ft IDE cable... because OcUK don't stock 7ft ones... is it still the same?
